k brown
Don't leave us in suspense!
Still need physical protection, though.
Not really commercially practical i admit. Additional mesh in close proximity to the diaphragm in front wouldn't hurt the sound. Coarse as it has no emi shielding purpose. I use them as overheads, or anywhere where likelihood of getting hit is low.Don't leave us in suspense!
The studio I work out of has two. They’re just blah, as in uninspiring. I’m betting the circuit could be replaced and that’ll make all the difference. That may happen one day, but maybe not. Between the two of us, we already have way too many mics! Still, it’s sad. Such a waste of two perfectly great capsules and bodies!
Tweezers!Not really commercially viable i admit. Additional mesh in close proximity to the diaphragm in front wouldn't hurt the sound. Coarse as it has no emi shielding purpose. I use them as overheads, or anywhere where likelihood of getting hit is low.
Not really a rocket science, the diaphragm is grounded, but the construction has to be such that the backplate is shielded from all sides by the diaphragm, and rear delay network backplate. So metal construction all the way around if you get what i mean. I have even one with built in smd fet and 1G smd resistor. They are "buried" between the backplats.
Oh, I see!That's one of the models I was refering to in my last sentence.
My point was, it was many years before they made another mic with a cylindrical basket - and I think it was done for purely marketing reasons.
I think it was done for 47-inspiration reasons, which was done for marketing reasons, which was done for what the market was asking for reasons.That's one of the models I was refering to in my last sentence.
I know.And at Recording Engineer - was in *no way* touting them. Just noting the headbasket and more recent production.
Will try them there next time for sure. There’s even a vintage B15 too!Try them outside kick (as you would use a 47FET) or on bass cab (like a B15)
In some cases, it'd be really easy: I've got one mic where I can swap at least three different head baskets without any other changes. I wouldn't be surprised if nearly every mic with the same diameter as the BM-700 can swap headbaskets, for example.Now what would be ultra-cool that no one has done before? Gather all widely-available and popular DIY head baskets to measure what’s truly what.
The answer everyone hates - it depends.How does a lollipop headbasket affect the sound?
Do you have an example of a well-designed lollipop headbasket?The answer everyone hates - it depends.
You have extremes like Soyuz, BM3000, or M-audio Sputnik. But in general, well designed lollipop with thin frame should be pretty transparent.
Thanks for info!!Geffell CMV563 capsule sounded and measured pretty much the same in the body, and outside the body when I tested it.
I should have added disclaimer that this is in my opinion, I like transparent headbaskets.
Not to say Soyuz design is bad, but it is definitely changing the sound of the capsule, and is important part of that mic's sound. BM3000 is terrible for example, as it creates large nulls in the response, and messes with pollar pattern.
Are those"Geffell CMV563 capsule " the old Neumann Lollipops?Geffell CMV563 capsule sounded and measured pretty much the same in the body, and outside the body when I tested it.
Do you have an example of a well-designed loolipop headbasket?
