I found this hammond Dc choke , 320mH 600ma
comes out around the same DC resistance as the one used in the N52a , 7 ohms by my calculation .
Its around 10 dollars to buy .
Thanks again for the docs on battery noise Gus ,
Its in nice clear language anyone could understand .
Seems like Ni-Cad is the winner in terms of noise ,
AA size apparently came out best in the testing ,
Nicads arent as common as they once were , but there are still plenty of cell packs available for emergency lighting systems and medical equipment , AA nicads arent that common any more , as in domestic use their likely to end up in the trash .
As far as I can tell the batteries in the N52a are 300mah , so maybe an hour or twos worth of heater supply max .
A modern Nicad AA cell has around 900mah ,so it could last several hours without the need to recharge . Larger 3000-4500mah cell packs are also available .
https://jandkaudiodesign.blogspot.com/2015/04/2-coil-choke.html
I was wondering how common mode filtering might be applied to a battery heater supply , there is a 0.1H common mode inductor easily available , dc resistance and current capacity are about right at 3.2ohms/450mA
https://uk.farnell.com/triad-magnetics/cmf16-104450-b
I was thinking of two three cell battery packs center tapped and connected to cathode/ground , then the grid bias tapped off one cell down on the minus side . Charge is applied to either end of the chain of cells .
