Based on my transformer, I boosted the regulator voltage by only 3 volts.C8 isn't that important, because the output impedance of the regulator is very low. (Near zero ohms.)
The capacitors after the first and second added resistor will make a big(ger) difference.
Will 2 filters after the regulator be enough to reduce hum and noise, or is it better to sacrifice the regulator and add another filter?
