Ted Krotkiewski
- Joined
- Nov 4, 2018
- Messages
- 57
ruffrecords said:The most likely reason for not enough boost is a wrong value pot or 5K1 resistor. These form the basic 14dB pad that defines the maximum boost.
Thank you so much for your help Ian! Cant thank you enough.
Quick report of my further findings.
Firstly, Indeed stupid me, forgot the 5k1 resistor in my breadboard.
The boost is now acting as should. (Yayy) ;D
Regarding the non-linearity on FLAT setting:
It appears that it is the Bass section affecting the circuit. When I disconnect the Bass section, I do get a "Flat as a pancake" measurement. Even though it is set to zero boost, I get a veery wide (10Hz - 2Khz ! ) boost of about 3db.
Do you have aaany idea (again) what I might do wrong?
(Please see pictures)
Then I also discovered that the general boost specifically the MID was greatly affected with and without Opamp at EQ output.
With Opamp +15dB
Without Opamp: +19dB
Is this normal?
Thank you for your time!
//Ted
