HELP! Building Green Pre schematic with 2xNE5532 (Newbie)
tunca
Hi!
I want to build 2 Ch Green Pre but i can't build V14 Green Pre.Cuz i'm newbie and i want to build simple schematic like that http://mhumhirecords.org/DIYpics/3.jpg But i can't find schematic with 2xNE5532.Anyone have?
Actually i found it
http://web.archive.org/web/20061214092614/http://1176neve.tripod.com/id10.html
but i want to be sure it's true schematic  ???
skal1 said:
Newbie's,
check the meta at the top of the page peace
skal1
I checked the meta but i didn't find.There was only new versions of Green.I'm looking for old version with only 2xNE5532.
By the way i have questions.I can't understand somethings on overlay.Can you explain?They are input/output?
http://imageshack.us/f/607/askgreenoverlay.jpg/
gemini86 said:
Transistors, inductors and pads for in / out and off board connections.
Thanks.I got it.
1.There were 2 transistors.Transistors are BC550BP right?Cause there were not on overlay.
2.Well,F2 is inductor.But where is inductors value?
3.Which connection is input? Which connection is output? And which connectors are switch and pot?Can you show on overlay?
gar381 said:
The wayback machine schmo is the correct one.
Check with peterc with questions as this was his project.
Use BC550C not BC550B transistors.
Have fun with your build. :)
GARY
Thanks Gary!
I will do what you say.
The inductors are indicated as ferrite beads.  I have not built it but I suppose 2-3mm diameter ferrite bead with a single turn of single strand wire for RF protection will do it.
The in/out are 3 way headers. The one on the left is input, the one on the right is out. You are just going to have to start reading the schematics and following the components on the pcb layout. It is not difficult.
OK! I got it,i guess.
And it's what i understand  ;D
http://imageshack.us/f/831/greenoverlay.gif/
Thanks for everything!
Now i need something esle.I didn't understand power supply schematic.Where is it?
I think that's it right? http://web.archive.org/web/20061214092735/http://1176neve.tripod.com/id11.html
And i will use 2x15 V power transformer right?
Thanks to all Gurus!
