Help modifying a DigiTech powersupply
jwhmca
USA
I'm working on the internal power supply for a digitech Genesis 3.
I wished I had the schematic to post , but I can't find it anywhere...
Here is the issue. The unit seems to reset randomly. It most definitely seems worse when running from a generator (like diesel, I tour abroad a lot)
I took it apart and found a 3.3 volt regulator (BA033T) that runs really hot (can't leave finger on it)... Now here is where I'm at. The 3.3reg spec sheet says it should be "bypassed" duh. It says a 22uf tant is ideal. Digi is using a 10uf aluminum elec... Tant for heat stability I'm guessing?
They also recommend a .33uf on the input to ground which digi did not install. The heat sink is a joke.
Here is the deal I need help with. Of course, if any power Brains can think right away the solution or already know of this... fine But, I need to do as much as possible before my next show cause I have no way to test it here.
Does adding the input bypass cap protect against what a deisle generator might put out etc...
If the VR is running really hot but putting out clean 3.3V perhaps look nearby for a problem. Perhaps something the VR is powering is drawing excessive current, or the un-reg feeding the 3.3VR is higher V than designed for (uncommon but worth looking at).
I had a tiny SMD 3.3 VR running too hot to touch in a prototype and it was because the dumb design engineer (me) didn't properly account for power dissipation.
John,
Do you think that running it off from "generator power" could cause an issue in not having the input to the regulator bypassed?
