MatthewMachinist
Member
- Joined
- Aug 19, 2020
- Messages
- 10
Hello team
I am in the process of working with a pcb designer to design pcbs for the Group DIY Reddi DI project.
Attached are some images of the board.
My question relates to the HH 6.3v DC supply for the tube heating. My understand is that pins 4 and 5 are for heating.
The pcb designer has made is so that both 4 and 5 are positive. Presumably he is assuming that the current will return via the ground pin.
I was thinking along the lines that pin 4 should connect to positive and pin 5 to ground.
If anyone can let me know I would appreciate the help.
