industrialarts
- Joined
- Oct 1, 2020
- Messages
- 135
Also, if someone could explain - why are the two triodes run in parallel? Impedance matching? And, could they not use the same cathode resistor and bypass cap?
Sort of. It reduces the impedance seen by the primary, which is always good for the xfmr response. In addition it results in a small noise benefit of about 3dB.Also, if someone could explain - why are the two triodes run in parallel? Impedance matching?
There's a (very) minor benefit in making the circuit less dependant on matching of both halves of the tube.And, could they not use the same cathode resistor and bypass cap?
Is it usual for a tube buffer circuit to have such high output impedance? The note on the schematic says 130 Ohms transformer DC resistance, plus 600 Ohms discrete resistors, plus the reflected output impedance of the tubes. Seems very high for a balanced line driver, but I am used to dealing with solid state gear, so I don't know if that is normal for tube outputs or not.Sort of. It reduces the impedance seen by the primary, which is always good for the xfmr response. In addition it results in a small noise benefit of about 3dB.
Considering the application, I don't think noise is a real concern.
Not really "usual" but usable in the context of bridging connections, where line inputs typically exceed 10k. Even if connected to a mic input (worst case 1500 ohms) it is adequate.Is it usual for a tube buffer circuit to have such high output impedance?
I just seached reddi DI schematic
What is the point of a DI using so much power?
The PS in the schematic in this thread needs help.
9AJ is the correct pin-out for your chosen tube.Are you sure it's a 9AJ
This site says B9A 6N1P @ The Valve Museum
The tube fits a B9A socket... are they interchangeable.
