moamps
Dr nEon said:....I do have some brand new 6u8 35v tants in stock, and I wonder if it would be safe to temporarily sub with those...
If it works with 4u7 as power supply bypass, it would also work with 6u8 for sure.
I had a production error back in the early 80s where an aluminum electrolytic cap was installed backwards in a production run. It was a relatively low reverse voltage maybe 7.5V across a 25V cap... I did testing to see if there was a problem and they showed no apparent symptoms, but in the end I had them replaced... because when in doubt do what's right. 8)Dr nEon said:Thanks for checking that out, John! My voltages are good, so I'll install the caps properly.
I'm amazed that cap has sat there happily all these years time before finally failing... perhaps the 35v rating made it robust enough to handle the reversed situation.
Thanks again,
nEon.
JohnRoberts said:... because when in doubt do what's right. 8)
