sonolink
Hi all,
A friend has a sony zv1 camera. My question is related to the audio recorded by the input of the Camera. The input of the camera is set digitally. If you set it to zero, it cuts the audio, if you turn it up to the max (30 on display) you get "wind" and a lot of gain.
A dynamic mic plugged direct into the camera, saturates the input of the camera from level 15 up.
With dynamics and lavaliers all is perfect. Zero noise and great sound. My problem has started when I want to record with condensers. I can't get a clean signal with them.
Problem 1: With the input of the camera low, I have to raise the signal of the Mixer that sends the signal of the mics. When I do this, I get saturation.
Problem 2: With the camera input high and the mixer low, I get "wind". Half way of the camera input, I get the best results but they are not even close to what I get with a dynamic or a lavalier.
The camera's input impedance is unknown. The output impedance of the lavalier mic is 1k, Impedance of a dynamic 150R, Impedance of the mixers used 120R.
Can anybody explain what's going on and help please? I'd like to sort it out but also understand the problem. Thanks
Sono
Sono
