sonolink
Hi guys!!
I built 2 Fuzz circuits based on the classic Arbiter Fuzz Face. They both sound great BUT they have some noise I'm trying to get rid of. Both circuits are the same, only some components values are adjusted to tune them with the transistors used.
Circuit 01 is using a BC338 as Q1 and a 2N3904 as Q2. It sounds fantastic and has a huge range of colors and textures BUT, hisses all the time. Even when the guitar is unplugged.
Circuit 02 is using 2N3053s. Same as before only there's some high pitched noise and some static instead of hiss.
I tried modding both circuits after reading R.G.Keen and other posts but I can't get rid of those noises. I know that this circuits has an inherent bottom noise but I'd like to try to minimize as much as possible. I've attached schems and audio. The ground noise is mainly due to the circuits being breadboarded.
Circuit 01 schem:
Circuit 01 hiss:
View attachment Fuzz Test 04.wav
Circuit 02 schem:
Circuit 02 high pitched noise:
View attachment Fuzz test 01a.wav
All your ideas and suggestions very welcome as usual.
Thank you for your kind help
Sono
Circuit 01 schem:
Circuit 01 hiss:
Circuit 02 schem:
Sono
