sonolink
Of course. Thanks for checking. I've had a few smokey missiles in the past hehe
Depends where your DMM is connected...sonolink said:To have an increase in Gain, I should read a decreasing resistance on my DMM as I turn the pot clockwise, right?
abbey road d enfer said:It certainly does matter! The wiper is generally the middle pin.
You may see input on wiper (pin 2) particularly on some Gibson guitars, but also in some cheap mixers.sonolink said:Ok. I would've thought so and always thought one was the input and the other the output but I've checked several schematics and some places the input on pin2 and others on pin3,
abbey road d enfer said:You may see input on wiper (pin 2) particularly on some Gibson guitars, but also in some cheap mixers.
Do you mean HV1 is lower than HV2? I would think it's normal since HV1 has a 10k resistor in series. If you draw 10mA from this rail, the voltage drops by about 100V.sonolink said:I've built a PSU for the little beast. It should be fed with 9V/1A and provide 2 lines of HV (190VDC) and a 6VDC line for Heaters. I get everything ok except that one of the HV lines reads aprox 80VDC instead of 190 like the other one.
Any ideas as why this could happen and where to begin looking?
Can't read it; way too small.sonolink said:This is the original schem:
Clearly, if you have 190V at HVA, you can't have 190V at HVB, unless the current draw is zero.sonolink said:Sorry. here you go:
Yes; check Ohm's law.sonolink said:Is that normal?
Ok. I'm not very good at this but I'll tryabbey road d enfer said:Check Ohm's law.
The voltage drops, but because there is a capacitor it takes some time; this time is governed by the current draw and the capacitor value.sonolink said:Ok. I'm not very good at this but I'll try
Ohm's Law states V=I*R
So, if Resistance is a constant, voltage is slowly dropping because current is diminishing?
When you connect your meter, it draws some current, admittedly very small, so it takes a long time to discharge the capacitor.Maybe because there is no load connected?
Because the voltage is regulated.But then, why is it not happening on the Heaters terminals?
I told you I wasn't very good at this.....abbey road d enfer said:The voltage drops, but because there is a capacitor it takes some time; this time is governed by the current draw and the capacitor value.
Of course...the 7806...silly me...abbey road d enfer said:Because the voltage is regulated.
DaveP said:The DC coupled cathode follower is crucial to the best sounding amps as that article will explain....do not change it!
