Indeed! I misread on the first pic.according to schematic it is a transformer with 375VAC secondary, but this P-TF22772 is rated different, see attachment.
Remember that the rated voltage is for full load, so unloaded, it's somewhat higher. Typically the open voltage is about 10% above loaded voltage. The measured difference is much higher than 10%, so there is something wrong somewhere.The peak voltage from an AC signal is V_rms*sqrt(2)
The V_rms at the wall may be somewhat higher or lower than 120V, but if it were 120v exactly, the V_rms of the secondary would be 325v. The V_peak then would be 460v. That should be the highest voltage you could see in your circuit (and you'd want all your HV caps to be a safety factor above that). I'm not sure how you are seeing 550v in this situation.
The main purpose of a thermistor is to limit the current surge at turn-on. It allows reducing the nominal value of the fuse, resulting in better protection.I'll put a thermistor in there for sure, primarily to slow down the voltage on startup.
What would you and Cqwet Dbdfte have to say about the actual sound of the SS rectifier on an otherwise tube-built amp? How would you describe its sonic attributes?
Some people prefer SS rect others prefer tube rectifier
SS is not 'kinder' on the transformer (if anything a tube recto is kinder because of its resistance and slow warm up). But SS gives you more freedom: you can use lots of capacitance if you want to, or not, you can add resistance if you want more sag*, or not, you can add a soft start circuit if you want to, or not.Its been pointed out that SS is 'more efficient' and won't burn out the PT as quick.
