Here's what it reported:
To accurately calculate the voltage drop across the series resistor with all three tubes (6AT6, 12AX7, and 6V6) in place, we need to consider the total current drawn by all these tubes combined.
Let's sum up the currents we estimated earlier for each tube:
- 6AT6: 0.15A
- 12AX7: 0.3A
- 6V6: 0.79A
Total current draw total=0.15A+0.3A+0.79A=1.24A
Now, we can use this total current draw to calculate the voltage drop across the series resistor.
Given:
Initial voltage: 403.2V
Desired voltage: 350V
Voltage drop =403.2 V−350 V=53.2 V drop
Now, using Ohm's Law you would need a resistor with a value close to 42.9 ohms.
This is why you can’t trust AI for anything technical.
That AI can’t differentiate between heater currents and plate currents, and it certainly can’t tell you to consider the difference between quiescent current and current drawn when signal is applied.
Stop using AI and put a small amount of time and effort into understanding how to use ohm’s law and the relationships it describes, how to read a datasheet- esp for tubes, and a basic understanding of the parts of a tube and how current flows in it (ie: so you know basics like the scale of the current flow of plate versus filament versus screen and don’t get fooled into huge mistakes by a dumb AI algorithm)
Incidentally most old 6V6 tubes would tick away quite happily at 400+ volts for a good long time as long as plate AND screen dissipation were carefully considered in the circuit setup. Many current production tubes will also function similarly tho at a shortened lifespan. The current production JJ 6V6 is spec’d at 500VDC on the datasheet and I can tell you from a significant amount of experience that it’ll take 450-475vdc all day long for a very reasonable lifespan. Of course it’s constructed quite a bit more like a 6L6 in a smaller bottle- but still.
Consider that almost every classic Fender circuit and all the modern reissues that use 6V6’s are running between 390-440VDC loaded on the plates- and these amps are produced by the thousands and are generally running the cheapest chinese or russian tubes Fender can rebrand. And they all function reasonably well with regards to tube life. (Of course they’re biased cold as ice from the factory, but that’s easily corrected and they still work fine)
If you used a current production JJ tube in your amp as-is, biased it respecting dissipation and keeping it to 55-65%, AND throw some reasonably sized screen grid resistors on there (~1kOhm) following a decent dropper for the screen node- you’ll probably make 25-30W and the tubes should go for a good long time.
If you wanted to use any current production tube- esp something that sounds a little more like a classic 6V6, then sure, knock your B+ down to 425-450 with a big ass zener, do all of the above, and call it a day.
This is a guitar amp, trust me when i say not only do you not need regulation- but adding a regulator circuit in this instance is adding more circuit complexity that you don’t need and more things to fail. And when things fail at 450V they tend to make other things fail along the way. (Ahem: every modern traynor amp i’ve ever fixed with their stupid over complicated power supply design) and that kind of tight regulation will work against most of what you want _tonally_ to happen in a guitar amp. (Unless you play speed metal)
ALSO- unlike the capacitors in circuit- which DO care about a static voltage difference across them exceeding ratings at all times- you could put 1000V on the plate of a cold tube and it wont care (ok, a slight exaggeration but i digress). There is no current flowing in a cold tube so the tube is not dissipating any power. If your no-load voltage with the tubes out is 500V, but drops to 425v when under static quiescent load conditions then the 425V is the only plate voltage you need to realistically worry about in real world conditions for the TUBE PLATES (again- capacitors need to be rated a healthy margin over the peak B+ at any point if you want them to last)
In practical terms- clip your dmm between the plate and cathode (this is the _real_ plate voltage the tube sees and is less than full B+ to ground) and see what happens when the tube warms up. I promise any not already failed 6V6 isn’t going to explode or catastrophically fail because it sees a few seconds of higher plate voltage than spec.
If it settles in to anything under 450, I say slap some screen grid resistors on, keep screen volts lower, bias to 60% and plug in your guitar.
