Greg
Adam, I'm sorry I really meant a wiring diagram of your grounding scheme. So I can see what and where it's tied to your star ground.
It looks like you are still wiring Chassis ground on the Hot Rod but it is really going to JLM 0 VDC . Disconnect chassis ground on Hot Rod and wire and connect it to 0V/Audio Ground on Hot Rod.
Yes, it is getting 24+ and 48+ properly when not hooked up to the Neves. I don't know if the VRegs are heatsinked. How do I do that?Is your JLM PSU (ACDC?) working properly when it's not hooked up to your pre? You're getting +24 and +48 right? Got those LM317's heatsinked properly?
So Adam, remove the 10R on both Hotrods and do not connect the Earth wire on either.
