[quote author="bluezplaya"]Okay, I am tired of f@#king with this grounding issue on the Neve. This shit is just way too complicated at 1am. I need someone to help pull me out of this hole I'm digging myself in :sad:
1. I'm using JLM AC/DC 3 Rail PSU, Output Transformers, and Go Between
2. Both XLR in and TRS out PIN 1's (audio ground) are all connected to PSU 0v
3. Pin 6 of 31267 and Earth from Hot Rod boards both connected to chassis, which is connected to earth pin of AC inlet.
4. 0v from PSU is connected to earth ground from AC inlet
5. The way it is hooked up now, my 1 watt 12ohm resistors on the Hot Rod boards are smoking :shock:
Questions:
Do the output transformers need to be earth grounded? If so, how?[/quote]
re # 3: Hot rod Audio ground next to +24V should go to JLM 0V. Assuming you are using a 10R and .1uF cap on the JLM, and taking the ring connector to chassis on the JLM. Your 283's have a potential ground loop the way you have it wired.
Ain't it a bitch. I am having a hell of a time with mine. many details on these.
