To be clear, are we talking about a threaded insert? Generally used on aluminum sheet metal that is too thin to be directly tapped for threads to mount things. Drill a hole in the sheet metal, use a puller to pull the gripping splines of the steel insert into the hole to the point where the larger round flange bottoms out and prevents it from going all the way through. The inside has the threads of interest.JAY X said:I have a metal box and i have to remove a screw rivet from one of the foldings. It is an M3 screw rivet.
sahib said:Although I have removed a similar one from a prototype last year, having checked this one it seems it compresses on both sides. If that is the case then you are absolutely right that it should be drilled out.
