nrgrecording
After some weeks of anger... :? I would like to report that the Corel Draw Versions 7,10 and 11 makes mistakes with the HPGL export. A 100%correct HPGL output is not possible.
Recommended is the Corel Draw version 9.
I'd have some trouble with wrong distances, wrong placement...
I always have to readjust the file in corel draw (to incorrect placements..) to get the correct output file.
This problem is mentioned on a german cnc webpage...
http://www.easgmbh.de/cnc/cncmaschinen.htm (german only)
I played around with some files and tried to import them to their
cnc program and some errors appeared.
With Corel 9 everything works fine. (Corel 9 is also cheap - because old) :wink:
______________________________________________________________________
Their CNC engraving maschines are also very flexible :green: :green: :green:
By the way... does someone have the HPGL tattoo file of robbie williams or ozzy osbourne? :wink: :green:
Frank.
Frank.
