When I build with the syt5 I swap out a lot of parts personally, different plug different rails different Mount plate
Do you fabricate the rails and mount plate, or buy them somewhere? What do your replacements look like?When I build with the syt5 I swap out a lot of parts personally, different plug different rails different Mount plate
Wow thanks for that! Probably more than if i just ordered one directly. Customs to Norway are also an issue. I am pretty sure the rest of the construction is just fine if this issue below the capsule is resolved. It can be filled with some stuff...I have 3 empty ones sitting here… Wonder how much it’d cost to send one to you. Not cheap I’m sure.
honestly as long as they stay in the tightened position they remain stable for a while. it's repeated tightening and loosening that compromises them in the short term. long term stability (10+ years) I'm not sure. check how much the pins on the xlr insert are rotated when assembled from the orientation they were in before the bottom piece went on. check for loosening of the screws connecting the rails to the plate from bendingI have 7 mics in SYT-5 bodies. Haven’t had any problems whatsoever yet. I’ll check to see if anything is loose on any of them tomorrow. I suppose, if it is a problem for me, from this point-on, I will check every time I get them out and every time I put them away. We’ll see if I need to.
We must remember that even though they “attempt” to mimic the originals … the SYT-5’s are mediocre at best …honestly as long as they stay in the tightened position they remain stable for a while. it's repeated tightening and loosening that compromises them in the short term. long term stability (10+ years) I'm not sure. check how much the pins on the xlr insert are rotated when assembled from the orientation they were in before the bottom piece went on. check for loosening of the screws connecting the rails to the plate from bending
What i have noticed is that the height of the capsule in the headbasket, maybe also the shape of the capsule holder, makes a difference in the 4-5 khz region in an M49 clone.I've often wondered what would improve in the sound of a Neumann M49 if the flat plate below the capsule were treated with foam, or a hemispherical diffuser were added.
Anyone tried either, with a clone?
Well, that's more of a U67 body and basket than M49.I have a conical rubber diffuser in my SYT5 the mesh in the headbasket seems to be randomly placed though
Sorry; thought you were responding to my query about M49 or clones thereof.I know but NOS K67 in a SYT5 body was the general direction
Where did you source this if you don’t mind me asking and do you find it’s made a difference to the mic?I have a conical rubber diffuser in my SYT5 the mesh in the headbasket seems to be randomly placed though
