No. I was not able to do that, so I bared the lower mesh, already spray painted before fitting, which is a tight fit in the body, and then glued it in place where it joins on the vertical, as well as spots on the top and bottom of the mesh. The mesh was made by rolling it on a former to make a cylinder that fits neatly into the body. For the top, I made a die, not as glorious as yours, but it works, and after forming the mesh top, I cut it to fit neatly in the top. Glued in as well. Then I made sure I had bare metal contact to th mesh as the rest to the innards slide in to the body, and a thin copper flat spring to maintain contact. With any of the mics I have made, I have had no trouble with the mesh earthing to the body. Hope that helps.
Kind regards,
zephyrmic
