micolas
And with the sea breeze, in the summer, how do you solve it?
I avoid to go outside in winter...![]()
Understandable and wise.
Hi @Emmathom!Another test with acoustic guitar 6 feet from mics, Line Audio & PUI5024 side by side.
- PUI5024's output level does not decrease the further you go (so I really need to dim that)
- PUI needs indeed to have its capsule pointed up, not to the source, otherwise some unpleasant highs appear
- PUI needs an EQ but less pronounced than I first did
Set as above, the PUI5024 becomes usable and delivers a pleasant sound, different from Line Audio but with its own character. A slight more bright, a slight less mids... (need to play a bit with EQ)
I will put them aside the Line Audio next time I record a real ensemble in a real acoustic and then I'll be able to have an real opinion...
Last circuit attached (much more "normal" about output level)
It would need real measurements but I haven't got the tools for that...Hi @Emmathom!
How would you compare the SNR between the two microphones in real conditions, in your applications?
Philippe, Thanks for the info!It would need real measurements but I haven't got the tools for that...
Just by listening I'd say no more noise than Line Audio with same recording levels but as I said the gain is set higher on the Line Audio (to get the same recording level). 10AM for PUI / 2PM for LA. On a log pot that's not so much but thanks to the 150K resistor (much more "normal" output level than with the 83K)
Yes I thought about inserting an passive EQ in... but let's do it in post for it gives more latitude...Philippe, Thanks for the info!
(I used to have fun with this type of simple circuit in the 80s, I used to extract electret capsules from Japanese radio cassette players, I also built lathed aluminum bodies and experimented with different headbaskets, I even incorporated a simple passive EQ that lowered the level but it was ok, they had a high output level, they sounded better than dynamic microphones: Soviet or Philips, Unitra etc)
EM273 is a 3 terminal electret so ideally suited for SimpleP48RCA. No need to modify the capsuleI could be interested in building the same kind of DIY mic but with the Primo EM273 and I suppose I can refer to Ulli's circuitry... ? For EM272 I guess the circuitry is much simple... as it is for the PUI5024
+1EM273 is a 3 terminal electret so ideally suited for SimpleP48RCA. No need to modify the capsule
This has 10dB less gain, 10dB less distortion and a max. spl of 130dB or better
It (surely) closes the vents and maybe add an EQ or some circuit : do someone knows how it works ?
Hum... many users and mic designers according to say that closing the vents only does not make a cardio into omni... but if you say so and if Shure does soIt closes the vents, but that's it, it does nothing electrical. The circuits of the KSM141 and KSM27 are identical (apart from the bias voltage generator in the 27 since it's not an electret), and there's no frequency manipulation going on in either (apart from the switchable low-cut, of course).
Hi UlliORTF (2 cardioids, 17cm, 110°, trivial)
Sengpiel (2 cardioids 25cm, 90°, combining the two S502MKII)
NOS (2 cardioids, 30cm, 90°, combining the two S502MKII)
AB (2 omnis, 30..70cm, angle as you wish, combining the two S502MKII)
With some mixing you can produce almost all configurations on a "single microphone stand".
