micolas
So, apart from changing the polar behavior, you managed to get a nice "smile". Including a cheap mechanical/acoustic deeser.Here are my measurements. S502MKII capsule vents were sealed with self adhesive tape. BLUE curve, shows a 12dB bass boost around 180Hz and a 4dB dip at 5kHz. A three stage EQ leads to the RED curve, for my oppinion not bad at all. For comparison the cardioid S502MKII in GREEN. Of course we have a limited dynamc range, the max. SPL at lower frequencies will be limited to approx. 122dB...
Pls take the measurements with a grain of salt. No reference mic and not the best speaker at all, measurement distance was 50cm.
But if we consider the trivial approach with adhesive tape it is surprising how cheap an omni can be done
BR MicUlli
I admit that I am seriously thinking about testing the closure (gradually, of course) at the back with a disc (like the K103, Rode) of some LDC capsules that are too sibilant to be used on some sources.
The question is how an LDC responds to this mod.
