Improving the Coupling Capacitors for Better Tone Sounding
Although there have been a lot of advances in capacitors, some of the silver mica caps are definitely worth looking into.
Guru Scott Wurcer investigated caps for LN stuff. I had some correspondence with him on the subject and I think he put some of this in his Linear Audio articles on condensor microphone amps.
He found Polystyrenes microphonic and Silver Micas introduced a strange noise. The best small caps were NPO/CGO ceramics. If the voltage / values / size fit, use them.
Tantalums and some of the uber Electrolytics also introduce noise at a very low level. If LN is your thing, use cheapo Aluminium Electrolytics and bias them properly.
I never heard about the NPO/CGO ceramics capacitors at least with those names!; do you have more info about the Scott Gurcer study or investigation? Where I can find this investigation paper or notes?
Thanks a lot,
opacheco
Use only capacitors hand carved from Unobtainium and solid BS by virgins ! :)
If you send me US$100 in used bank notes, I'll send you a sample. You can just stick it to the chassis with BluTak to enjoy improved clarity and definition. No need to even solder it in.
No Confederate money please
Sorry what you talking about? I don’t understand nothing you say!
opacheco
……most friends who used tube amps with those old mustard yellow colour Mullard capacitors stated that the amp sounded best after twenty minutes warm up. Technically those caps were not so temperature stable as modern MK types, so perhaps there was some kind of drift. But I think we all probably got used to the sound after 20 minutes...
ok, I will considering that too!
opacheco
Hi to everyone!
I am trying to improve the tone quality of this tube amplifier at maximum! and I would like to know what kind of coupling and dis-coupling capacitors can I use in order to achieve this superior sound quality, instance to the actuals Mica cheap capacitors used actually?
I have attached the schematic for your considerations and advices.
Thanks in advance!
opacheco
Lots of mythology runs thru capacitors.
"Tone" is very subjective, and good coupling caps should pass the lowest desired frequency and not leak any DC as to destroy the bias of the next tube.
You can EASILY measure leakage with a DVM: remove connection on low voltage side of cap, measure voltage with the DVM, take the number of volts and divide by 10,000,000.
The number should be very small.
Old caps can be leaky, giving unwanted surprises.
Replace as suggested with PP caps.
Paper in Oil, PIO, may have some dielectric absorption effect, maybe audible. Maybe OK?
As "tone" is not measurable hard to say.
Some PIO are shipped with metal shorting clamps to keep surprises to a minimum.
10kV 4uF is no joke.
Coupling capacitor distortion is relatively easy to reduce. Now with reduced-size audio-grade ‘lytics (even tantalums), just oversize so they have barely any voltage drop at the lowest frequency of interest, say 16Hz, then calculate for f3 of 1.6Hz.
The reason: Oversizing means no voltage drop at the lowest frequency of interest, so there can’t be any distortion imposed. - Douglas Self
Yes, and.
When designing an audio path with multiple DC blocking capacitors, the HP poles in series accumulate, so it is just good practice to tune the poles well below the audio bandpass. Ideally in premium designs we try to use a single film or other very linear capacitor filter stage to define the dominant LF cut off.
The typical aging mechanism for electrolytic capacitors is loss of electrolyte, and therefore loss of capacitance. Tuning these DC blocking poles very low insures many years of useful product life with minimal audible frequency response changes due to aging.
Here's the straight science for your high-pass coupling cap break frequency. At fc you'll get +45 degrees of phase shift and an amplitude drop of 3 dB. If you move that break frequency down to 1/10th of your desired lowest useable frequency, the phase shift drops to +5.7 degrees. This means you use a capacitance that is 10 times the cap that would have made fc at your design's lowest desired usable frequency. Remember that cap causing the break frequency is the old C= 1 / (2 PI fc R). Another reason for pushing that break frequency down is that your amplitude response is going to be -3dB down at the original break frequency, but if you use a capacitance that's 10x what that equation says, your voltage amplitude drop is only 0.0995 of the original signal at your lowest useable frequency. If you use an even larger capacitance, the phase shift and amplitude response effects are even smaller. The cap value you choose is is limited by size, cost and availability.
I think at Neve back in the 70s we had a set of simplified equations for calculating coupling capacitors for 1dB, 0.5dB and 0.1dB loss at 20Hz for any given impedance. I will see if I can dig it out.
