callgrlmusic
Member
More of a theory question than anything—say you wanted to build an in-line pad for high spl handling.
would you do that between the rest of the circuit and the capsule? guessing yes, lower the voltage to capsule, lower sensitivity etc. would it be essentially the same thing as you’d use for a speaker driver in a crossover?
i have seen off the shelf solutions in line between the mic and the preamp, but wouldn’t that work less effectively in terms of capsule “loading”?
