freshtapescent
- Joined
- Jan 25, 2014
- Messages
- 51
Dearest enlightened persons of groupdiy-
I’ve got a set of Opamp Labs EQs, which are ‘swinging input’ a la ‘EQ AMP’ and everything Connected between pins 1&8 here: https://groupdiy.com/attachments/opamp-labs-1204-2a-jpeg.51868/
My questions-
1. What happens when an inductor saturates in this circuit? From theory I know…the value of inductance value plummets when the core saturates. So…in practice…you’re boosting 40Hz on the drum bus…+2, +4, +8…+12dB…sounds linear until saturation, then peaks of waveform saturate the inductor and for those moments it sounds like you’re not boosting 40Hz any more? Like the loudest kick drum on the downbeat of the chorus actually gets less (or no) low end cause its so loud it saturated the inductor? Or…peaks that saturate the core max out at +12dB of boost and then there’s just no more boost as you turn up the input. Like…it’s cranked up to +12, and pushing more level into the EQ basically doesn’t give you any more boost?
2. Do HF band inductors have to be large enough to handle the low end signals? For example, regarding question #1…will I lose a high frequency boost because a kick drum just saturated the high frequency inductor? Or is it just audio level within the band the inductor is passing?
3. Will they saturate the same whether they’re boosting or not? Same with cuts? If you saturate the inductor, does the answer to #1 still ring true? Like, cutting cutting cutting…loud kick comes thru, inductor saturates, you’re back to 0dB of cut all the sudden…it’s like the EQ is bypassed?
4. Do we hear increased harmonic distortion as inductors saturate…or are any distortion products somehow nulled because they’re injected into the opamp differentially?
Thanks!!
My questions-
Thanks!!
