Hi, I am looking for some inductors for a 1081 EQ. Mu-Metal potted with chassis PCB's would be very helpful. Interested in at least two sets of those (one low-mid, one high-mid). Also interested in at least four sets of the PM-PEQ inductors.
Can you do the neve style in a mu-metal can with the chassis mount PCB?
The mid section appears to use either one inductor for mid boost and cut and the Lo-mid/Hi-mid combination with an inductor each, which of these do plan to make?
Matt
Not sure if everything is set for this project yet, but I'd be in for 2 inductors (one for the low mids, and one for the high mids) for the PM Pultec.
2 of each for a stereo EQ of course ;D
I am definitely in for 6 posh men's inductors. Posh men inductors have two different values right, one for lo-mid and one for the hi-mid.
Edit:
So technically, there are 4 different inductors than you can choose from, they all use the same pm mid board. Will this variety present a problem for you Chrion?
And if not, I think we (= Chrion) should come up with some sort of labelling to tell them apart for us to order. done
I will check above assumptions and values with Ian, just to be sure. done
