info on unknown transistor connector
Whoops
GDIY Supporter
Portugal
need to find a replacement for a broken connector,
it's used in a Pioneer hifi amplifier as a power transistor socket.
Does anyone know any info on this?
brand or connector name?
thank you
TO220 transistor legs are 0.1" centers.
Just like DIPs.
Get a DIP-8 socket with the flat (not round) contacts. Bust off one side to make 4 holes. Cut off one hole. Stuff it.
Hi PRR,
I need the height this socket has.
The way the transistors are mounted on this amplifier is really strange. Also the package is TO-247
I have tried a DIP socket already, but I need 3 times the Height of a DIP socket.
Thank you so much PRR
gyraf said:
Just extend pins on DIP-socket?
At least for a TO220-housing, you can also use a standard 3-pin molex connector on wires.
Jakob E.
Not that easy.
The transistors are not socketed independently.
Theres 4 Power output transistors,
the 4 are screwed to a big aluminium Bar, that runs from one side to the other of the chassis.
When installed the 4 transistors have to be socketed installed at the same time, each to it's own socket.
I might just solder wires to the problematic one, but if I could find any info on the original socket that would be great.
I'm sure someone know what this socket/connector is,
and Im also sure that there are thousands in a workshop or warehouse somewhere on the planet
PRR said:
Wire-Wrap DIP sockets have long pins.
Thanks PRR, going to search in my local supplier for those, I dont have them in my workshop.
I will have to create something so that the pins of the DIP dont bend when the  4 transistors are inserted
The 4 transistor are screwed to the underneath of this big heatsink, and they are inserted at the same time and height on the transistor connectors:
