Hi guys !
Last year I successfully built a Gssl with Turbo and SSC and was just thinking about adding the Crush-n-Blend function to it.
Before I'm trying it out I have a couple of questions to you :
1.) Is the gain on the same overall level, no matter how I set up the Wet/Dry pot ? Precisely is it the same level for 100% Wet, 100% Dry and 50%/50% Wet-Dry or does it add a few dBs at 50/50 ?
2.) The "Make-up" Gain of the main VCA is controlled by a DC-Offset you add into the VCA CV. The Dry signal is added after the VCA after the first Opamp of the output circuit. Does this mean, that the ratio between Wet & Dry signal at the output changes if I turn the Make-up gain knob ? Do I have to change my Wet/Dry knob to get the same ratio of Wet/Dry ?
3.) Is it possible to set the knob the way that I have 100% Wet at one end and 50/50% at the other end ? I don't think that I will ever need a 50% to 100% Dry signal. I was thinking that I would gain more precise control over the Wet/Dry ratio if the setting range is smaller.
