All the real 2520's I have have the trim pin cut off so have never added the extra pin hole for it. But yes mounting the 10k resistor on the other side should do it. Just make sure the trim pin doesn't touch the PCB or it may rub through the solder mask to the 0v ground or it could hurt the opamp.One question...what do I do with the Trim pin on a 1731/2520? There is a 10k resistor in the way and I don't want to bend the pin or cut it off. Suggestions? Maybe mount the 10k on the underside of the board?
The OPA2604 is extremely fast and the 99v is fat with silky class A highs. The Hybrid is fast and tight low end with softer silkier top in Class A than the OPA2604 on its own. Don't forget the NE5532A IC opamp as it sits somewhere in the middle of the OPA and 99v.Has anyone heard the Baby Animal A-B'd between an OPA2604 and the JLM99v. I've got 2 99v+JLM14; 1 Hybrid(A/B)+OEP; 1 99v+OEP. I'm putting them in cases tues or wed. The thing is I've been curious if I should look into the OPA2604+OEP as a fifth or if I should add one more of the Hybrid/OEP or 99v/OEP so that I have a second stereo pair? I like having as many options as possible but having a another stereo pair gives me a lot of options too. Any ideas? Help me spend some money.
The 330uF 63v cap only needs to be in the right spot if you are running 62v power rail in to the BA. Have found that some of the 10ohm metal film resistor go open circuit just due to the charge up current of the filter caps. So all new kits have 10ohm carbon which do not do this and if there is a real fault will smoke instead of going open circuit with no external sign. So if you have a 10ohm go open circuit change it for a 10ohm carbon type. If the carbon starts to smoke you have a real fault. If it doesn't smoke all is ok.So here I am thinking I'm all hot sh*t for building 4 BA's and what happens when I plug the first one in? Blow a resistor up. Yup. Me in my newbie haste didn't notice the 330 cap mixed in with the rest of those big caps. I think I placed it in the wrong spot and placed a 470 there and placed the 330 in a 440 spot. So I've now taken the cap out and am out side smoking to calm down. Could this have blown the 10 ohm resistor?
Help please!
The 99v should have more head room than most pre amps so check that the + opamp pin is getting the full +48v or +62v and 0v opamp pin is at half the volts of the + opamp pin. Should be able to put out +26dBM (on 48v rail) and with our JLM111DC wired as 1:2 it can do +32dBM. The only clipping you should hear is the gear plugged into the output of the mic pre being clipped. Also if you are running high line levels into the mic pre don't expect the small JLM14 to take the level without having to turn the 20dB pad on.It seemed to clip sooner than anything
I think you mean between the diodes but yes soldering them together reduces the bias voltage from 2v (30mA) with the LED to 1.2v (4mA) with the 2 diodes. Just a small bit of solder will join the two pads no wire needed.On the Hybrid opamp the 2 square pads between the zeners puts it in A/B mode right? And if that's the case what's the best way to join them?
OK voltages below taken with opamp fitted but most voltages will line up with opamp not plugged in.So here's what I got Matt...
+in = 24.5v
out = 47.8v
-v = 23.92v
+v = 25.25v
Pin8 = 47.8v Do those voltages seem odd?
Can you send me a MP3 of the popping noise and any other strange sounds coming from the BA to my normal email so I can see if I get a clue to what is going on.BUT I still cannot turn the gain up much past half way without the constant popping noise coming up
:shock:BTW I notice that the clicking seems to come out of the mic, as well as the soundcard!
Yes they are smaller in size but fine. Basically any 1/4 to 1/2watt 1% metal film of the right value will work. If anyone is missing any parts from our kits feel free to send me a email with your address and missing parts list and we will ship them straight out to you.I seem to be missing two 220K resistors and a 47pF ceramic cap. No biggie since I'm ordering some other stuff. Would these work as replacements?
