JTM45 Build with various output tubes and GZ34/Solid State Rectifier
yep as i thought, had to be connected, now getting 465v on B+ wth diodes, will leave on now and see how hot the mains txf will get.
started at 23C its now gone up to 27C after about 5 minutes.
first 32uf cap connection is at 38C?
could it be a dodgy 32uf cap?
ive used a bias calculator which was provided in this thread, and it said that for EL34 at 70% it should be 43mA with 403v which is what i was getting.
is the bias calculator wrong?
Im now at 443v B+ so will adjust bias to 39.5mA
BTW. have ordered some KT66.
One of my concerns was it was getting rather hot, my only other concern is the bias, i am using a 68k for the 180k into the diode and a 5.6k then a 27k with a 50k pot, should i be concerned that this is vastly different than the regular setup of 180k into diode then 15k, then 56k into 50k trimmer?
