ok ripped this thing completely apart, traced all the grounds, some traces just end in space, used for reasons unknown, other connectors have a ground on one end only, confusing til you realize it is just the shield wire for the coax,
finally found a place for a pigtail lead on the chassis, circled in red, with no wire coming off of it, you can even see the ground symbol with circle stamped on the chassis next to the tab, so we just added a wire with a push on terminal from there to the tone stack-master volumes and viola, it works, sounds great, even got an email from Bob Jones, who designed this thing, he has one himself and also had to replace some of the pots, so nightmare over, next amp is gonna be an Epiphone Galaxy 25,
