Luny Tune
Well, I do kinda recommend making your own optos for one reason and that is to do just that; Build your own. THAT's diy!
But NSL or Vactec optos will work just fine so it's not really necessary... But it gives you a sense of satisfaction to build your own.
And the danish groupdiy.dk is up and running again, SIXTYNINER.
Here's our danish shopping list for the LA-4. I'll keep an eye out for your questions if you have any.
http://www.groupdiy.dk/index.php?topic=1299.0
The LDRs are missing on it. I'll check up on it as soon as possible...
The part codes corresponds to this webshop's: http://www.el-supply.dk/
Here's what they write on the website about shopping from abroad:
"It is possible to order from EL-SUPPLY even if you live outside Denmark. Choose "Bestilling fra udlandet" when the order is send. You will then be contacted by EL-SUPPLY with information about how much you need to transfer. The amount can be tranferred using a credit card or our bank.
Please notice that orders from outside Denmark will be added a fee on approximately 10% or the total because of extra costs when receiving the money. The minimum amount added is dkk 10,-"
("Bestilling fra udlandet" means "Ordering from abroad".)
