camarada78
I have a Laney Cub 12R Tube Amp to fix a noise on my bench. It works normally but it has an annoying hum (120hz and 180hz are there but around 1k are the most annoying). It works normally otherwise. I know tube amps have some noise but this is too much.
- noise goes up and down with either volume or gain (as per schematic attached)
- tubes are new, same problem as with old ones
- amp has normal ground earth.
- the noise is there even without guitar, so its not pickup hum/noise.
I was suspecting some resitors (R13 and R28) but i changed them but the noise remained. Any clues?
My next suspects are R9 and R14. I will update soon.
