hoodun
Active member
- Joined
- Sep 17, 2014
- Messages
- 41
I know there are some other posts regarding this topic but I am not getting the info I need and have decided to try to consolidate some of the info I do know, or at least think I know.
Wiring an AM16 Module
In the past I strapped the in and out to 600hms, added a 20db pad switch at the input, and put a stereo 500ohm pot on the output. Is this the best way to wire these things?
Do I need the 500ohm pot on the output? Do I need to add a 680ohm resistor on pins 2 and 3 of the out?
Any info some someone with some knowledge they are willing to share is greatly appreciated. I am good with a soldering iron but a lot if this is, honestly, over my head. Generally I get power supplies kits from JLM and wire up inputs and outputs with a pad and 48v switch. I do not entirely understand the optimal way of wiring these AM16s.
Also, I found this old info about swapping transistors for extra gain and have actually done this myself but I never tested it:
Replace Q1-Q6 with 2SC2545
Change R1 from 680 to 560
Change R4/R5 from 150k to 390k (matched to .1%)
