I’m using an XTool D1 10 watt laser for panels as well as an air assist and enclosure.
I’m still experimenting with this process but found that using fill and offset fill as much as possible in light burn yields the best results.
The dials in the attached photo were created in Inkscape. Each time I tried exporting them as SVG or DXF and importing into light burn, only the lines of the object imported, making it impossible to burn them as a fill. I settled on taking a screenshot of the dial, importing the screenshot into lightburn, and using the trace tool to create the dials.
This trick worked for this panel but isn’t ideal. If anyone has some pointers on dial/scale creation, let me know
Settings used for all graphics on the panel were 100% power and 30mm/minute. I used compressed air to get any excess burnt material off, cleaned the panel with isopropyl alcohol and applied a clear coat before attaching the pots/knobs.
