Hi Guys,
Your thoughts on latching vs non-latching relay in a high on duty cycle... It's switching the PAD/48/PHASE on a micpre type situation. It seems there might be a lot of "on time" if I use a non-latching relay. Any drawbacks to latching?
If I use latching I need/must use momentary switch for triggering it?
If I use a toggle or push button switch that latches to drive a relay that latches will I burn something out?
The reason I ask, the EAO switches that I like (19-471.035) are latching with LED illumination. If I use the non-latching EAO switch, then I'm not sure how I would get the LED to stay lit... without another relay...
