Right. So I was correct, there is an issue with it depleting the copper traces. Is that just during the soldering, or over the lifetime of the joint?
I didn't buy solder after my post, since I didn't know what to do.
However, I discovered my old Kester "44" lead solder creates a lot of splatter in some cases, and large pools of flux residue around the joints.
When I made a Scott Dorsey mic mod, he stressed how you need to remove the flux residue to prevent noise in the high impedence circuit. I used off the shelf Ratio Shack lead free solder. It produced shiny, strong joints and very little flux around the joints and no splatter. So it's what I'm using from time to time. However, it needs much higher melting temp, and over time it ate away at the tip of one of my irons. Whao!
Also, someone said the fumes are very toxic, more than lead solder fumes, due to the chemicals in lead free...
Seems we have to choose our poison.
You're right, we should be discussing lead free solder, at least to know which ones are best, and how and when best to use them.
