Nishmaster
Hey gurus,
I've got a Hammond BV with a Leslie 122 in the studio that I'd like to plug additional instruments into such as a guitar, Rhodes, or other synth. I've done some research and here's what I've found so far.
The input to a Leslie 122 is a six pin connector, with two pins for AC, two pins for balanced input, and a pin for ground. Another pin sends 300V (200?) B+ back to the organ preamp for supply power. What I am unsure of is how the fast/slow switch operates.
I'd like to put together a simple tube circuit for this task. The Leslie amp seems to be about a 40W unit. I have very little design skills, but I was thinking maybe a simple SET type low wattage device, or maybe a single 12AX7. While I don't expect someone to put together a schemo for me (I'd prefer to work it out and teach myself something), I'd love if some of you all could give me some pointers/directions/laugh and point until I get it right.
One thing that strikes me right off the bat is that obviously guitars will need different input impedences than other line inputs. Will I need two input trannies, etc. I'd also like the thing to have enough drive to get the leslie amp a little dirty if need be, as well as having a switch for rotor speed.
I realize the BV has some Hi-Z input terminals, but I really like to put this all into a self-contained box since the 122 is obviously mobile (even if only dubiously), whereas the Hammond is stuck right where is it.
Thanks in advance to any and all that lend a hand. I really appreciated the responses in my thread regarding the oil dummy light for my bro's snowmobile. We went with ignoring the float bounce issue in favor of device simplicity, for those who were following. Works great.
Schematics of the units in question:
Leslie 122 Amplifier
Hammond BV Preamp Section
