I suppose an O-scope display is beyond the scope of this project, but it would be cool to have a little sine wave on an LCD. Is that even possible?
Got $200?
2MHz Panel Mount Oscilloscope, 6.5"W x 3.5"H x 1.4"D, eats 9VDC 300mA,
60-page Manual (well, 15 pages in each language...)
It's not the spiffiest 'scope in town, but it is 10 times faster than the 'scope I started on, and I learned a LOT of audio that way. And it never goes out of focus!!!!
Inside NYD's stated goal, general test-set, it's more than plenty. Leave the 50mHz on the heavy-research bench. An objection inside NYD's "portable" goal is that it could gulp batteries; might make the buzzer and squawker battery-power, and use a wall-wart if you find you need to see what you're doing. (But then you may as well just buy the pre-made LCD 'scope, which is chock-full of battery...)
Using a known resistive source impedance in series with the output of the sinewave generator and looking at the drop wrt frequency, you can perform crude impedance sweeps of speakers and such.
My Heath spent half its life that way, just with the resistor outside the box.
The gold-plated kitchen-sink feature would be a Constant Current output, so that impedance magnitude could be read directly on a Voltmeter. Push-pull pair of current mirrors and two resistors to the voltage-mode output. Just have to remember that when it is unloaded, the output will be brutal big square-waves (unless your microprocessor can watch that too.)
I'd lost track of Ed Dell and Audio Amateur mag
No wonder. This is the second time (in 30 years) that Ed let my subscription expire with only one notice. Try getting off any other mag that easy.
My impression is that Ed has stepped-back from the driver's seat. Anybody know how he is?
aren't some of the function gen chips based on a triangle wave out?
That's about the only kind there is. (ARP had tracking ramp-and-triangle function generators, but that's a frill not a difference.)
sine wave add on driven by the triangle out
As John says: I've not heard one that fools the ear near as good as it fools the THD meter.
Look at the shapes. The tri is "sharpest" where the sine is "flattest". You must move from nearly no change around zero to a very extreme change RIGHT AT the peak. The diodes and diff-amps make the triwave more mellow, but must be fine adjusted to reduce the high buzz, and it never goes-away completely. Post-filtering helps, but becomes as complicated as a decent sine-wave oscillator.
