Just got a LXP-1 and testing it out. Strangely, when the mix knob is on zero....dry signal is only on left channel in DAW. As i increase the mix knob and introduce the wet signal in, the wet signal only comes through on both channels just fine, and i can still hear the dry signal only on the left channel (until mix is 100% and then it's balanced between L and R channels. I've triple checked the wiring into the patchbay and even hooked the exact wires to stereo compressor and it worked fine. So i'm 99% sure the issue with with the device and not with wiring or the DAW. Anyone run into a similar issue routing stereo outboard gear through a DAW?
