Lexicon / Murata filters "De-potted" Detailed picture included.
jwhmca
USA
Hi Guys,
I'm rebuilding a Lexicon 480L. One of the Murata LPF filters is bad. I was able to "de-pot" it. Neat little guy...
Does the substrate have anything to do with the circuit? It looks like there is  little "pads" of carbon (or something) instead of SMD resistors?
Here is a close up of the filter.
Are those little "laser trimmed " resistors?
    335 KB
Yup, looks like laser-trimmed thickfilm resistors.
Browns are probably ceramic capacitors
Now is a great time to reverse-engineer.  Would be valuable information for anyone with a dead lex filter.
There's a very good chance one of the 4560 opamps is the damaged part. Remove them.
- With 4560's out of the way, draw schematic.
- Referring to schematic, measure capacitors and resistors: As the active stuff is out of the way, many points will be "hanging loose" and many component values can be read in-circuit.
- Refer to previously-drawn schematic to find the places where parallel loading disturbs component value read-out.
- As a last resort, desolder capacitor to read value.
- Use analogue filter logic to figure out/estimate the remaining parts.
- Solder back in three new 4560's and test for functionality.
...and oh, don't forget to document the whole process here !!!  ;D
Jakob E.
Hi jwhmca,
I got a 480L with multipy filter that are leaking, but the are all working at the moment.
So the need to be cleaned, a tedious work I think.
Did you use acetone to de-potted the Murata filter?
Or is that bad for it as it could damage it?
/Peter
