JW
I've been thinking about a box that splits the line level output of microphone preamps and/or other rack gear (compressors etc) on the way to the recorder (AD inputs) This would be a workaround in order to monitor with no latency with an external mixer, while I have the direct signal go straight to the converters.
Something like 8 in/16 out would be great. It's essential to keep the direct signal clean and un affected. Is the best way to do this to hang an opamp circuit in parallel off of the preamps outputs? (almost all of them are transformer outputs)
I'm not that concerned with perfect sound quality of the 'monitoring leg' as I am with maintaining the direct sound to the recorder.
