Looking for Behringer B-5 schematic
I have made my own, which goes very close to it and holds the same result. Since I fear scrambing, I include the text as *.pdf.
If you don’t like the theoretical calculations of Holger Pastillé, how do you explain the measurement results (for example, in Section 4 of the preprint version above), where the harmonics increase with an additional parallel capacitance?
For a short formal question to your document, I attached a PDF as well.
  • thd.pdf
    16.8 KB
Thank you for rising up that question. I notice that there is a mistake in my notations as the powers of k were missing after the equal sign. See pdf. Sorry for that.
To the first remark: I think it is not up to me to evaluate why the practical measurements do not correspond to theory (which was already given in a similar form referenced by Jan) but the other way round. I also believe the major suppliers of high quality condenser microphones would not run that trace if practice contradicts the effect. Such disagreement to theory should always be suspicion for weak points in the measurement setup.
  • B-5coRevision.pdf
    28.8 KB
