Looking for electret capsule manufacturer recommendations
Could you elaborate on that? My impression has been that condensers often have less LF rolloff than handheld vocal-oriented dynamics (and better HF extension too).
I don't think i was clear enough in that reply. When i say not much character i meant condensers are mostly flat in the low end. Yes, there might be roll-off or even a cut, but there are hardly any curves, nulls, bumps. So even if there's a roll off or boost it is linear, and it can be easily compensated with an EQ. Dynamics are different they can have all kinds of shapes in the low end so compensation with an EQ can be tricky.
Either way it seems like there's not much information in the bass (the bandwidth is narrower) and you ought to be able to EQ it better than the HF, because boosting HF exacerbates any circuit hiss.
Am I wrong? Is there LF circuit noise (rumble?) that's a problem that limits your ability to boost the bass with EQ? I would think that LF rumble is usually ambient noise, e.g. from trucks driving nearby or room mode boom, not a mic issue per ser (unless you have a bad shock mount), so it's going to have the same ratio to LF signal whether it's boosted or not. (Boosting a weak LF signal will also boost any LF noise, but won't change the ratio.)
You are absolutely right.
Good day!
For the record, I have been used both the open and grill version of these condenser capsule, and a similar capsule which has a blue plastic back plate, with success in several microphones over the past couple of years - even before this thread, so I am feeling pretty stud after reading good reports from others here. [Perhaps someone will tell my wife I was right for a change! She won't believe ME . . .] :)
I put one of these capsules in a Samson G-Track and one with the blue back plate in a CAD GXL1800 with pleasing results over stock JLI 16mm type capsules. They work well with computer speech recognition applications and online Zoom meetings.
I prefer the versions with white or metal back plates over the version with a blue plastic backplate, although it is totally subjective, and I cannot really say why. I second KingKorg's assessment they are realy good with speech up close and personal.
I, too, am amazed they arrive safely in a glassine baggie inside a grey plastic shipping bag, with no protective packaging. Crazy lucky, I guess.
Just my take - merely reinforcing the trend with my experience. James
blue backed condenser capsule front IMG_3429.JPGblue backed condenser capsule IMG_3425.JPG
An update on the venerable "KK12 v2" capsules.
Revisiting a couple of mics I built with these, I found that their ~hypercardiod pattern can brought much closer to cardioid by blocking four of the rear plate holes. It also produces a flatter response from behind and a bit richer overall sound (a slight mid/upper mid dip perhaps); also seems to reduce the low end roll off these are (in)famous for.
Overall tonal balance is nearly indistinguishable from my AKG C 3000 B with the @kingkorg mod.
https://groupdiy.com/threads/akg-c3000b-5-min-mod-awesome-mic.67911/
I'm now liking these capsules so much that I put them in these 'M 49-ish' mods I did to BM700 bodies (in place of the AT825 capsules I had in there):
    436.9 KB
I'm now liking these capsules so much I put them in these 'M 49-ish' mods I did to BM700 bodies (in place of the AT825 capsules I had in there):
I share your kink love for short(ened) microphones so I'm planning to improve i.e. shorten my BM-700 clad OPICs. Please advise how did you solved the frame removal issue? I have a few ideas but additional insight would be valuable.
Tasam/Marantz/ISK body is a no brainer. Can do it with my eyes (half)closed but BM700 is a bit trickier.
I tend to be a pretty crude 'cobbler', so I just cut the side rails to the desired length, then epoxied the frame back together; trickiest part is holding the parts in alignment while the epoxy sets - the fast stuff is your friend here. I used a small amount at first just to hold the parts together, then bolstered the joints with a second, heavier application around them (I must admit, it wasn't fun). If I did it again i'd probably just fashion new rails from brass strap.
When you shorten the body tube, cut off the top, so you retain the stepped lip at the bottom that the heavy threaded ring seats into. Then you need to file a notch at the top of the tube that you see at the top of the stock tube.
Here's a pic of the whole thing, with integral swivel and captive cable (inspired by the Neumann swivel adapters; Geek alert!):
    146.3 KB
    184.5 KB
How are you measuring your cardioid mikes behind?
At what distance?
Perfect Cardioids should NOT measure flat from behind at 1m.
At what distance?
No measuring, just listening and comparing to other, unmodded cardioids. It's not hard to discern a deeply scooped response from behind, from one that is far less so.
It is the natural property of single-diaphragm directional capsules for their rear response to become flatter as the pattern widens. It's the main reason Tony Faulkner prefers the MK 21 sub-cardioid on his four-mic array. Below are the (rarely seen) actual responses of Schoeps capsules. You can see as the pattern goes from supercardioid thru sub-cardioid, the rear response gets flatter and flatter.
So take my assessments with a grain of salt, and try for yourself (and measure if you have that capability). I offer these remarks to prod others to their own experiments. As with most things, YMMV.
    6.8 MB
(...) I just cut the side rails to the desired length, then epoxied the frame back together; (...) If I did it again i'd probably just fashion new rails from brass strap.
Thanks for full info 👍
The epoxy method came to my mind first. It's crude but simple. Though I'm always a bit vary about epoxied joints, they tend to break (com off one surface), in spite of what manufacturers claim.
Definitely joined surfaces absolutely need to be roughed and degreased thoroughly.
Therefore I was thinking along the lines of shaving the rails entirely and using threaded rods.
BTW you do know that epoxy, when heated, gets malleable. Helps repositioning or straightening.
Thanks.
As the shortening will be done on a lathe, the lip is not an issue. Can be redone.
But, yes, it's a thing to remember about.
Here's a pic of the whole thing, with integral swivel and capative cable (inspired by the Neumann swivel adapters; Geek alert!):
Nicely done!
It looks pretty cool in its compact body.
How did you cut the body? Hacksaw? Some sort of machine saw? Laser beam? I am concerned about getting it straight across. It would not look good if it ended up on an angle! Most of my workshop equipment is for working wood, so I need to consider how to cut it straight. I can just see myself cutting it off kilter and trying to straighten it on a grinder ... you know ... taking more and more off trying to get it even, until there is too little left ... If you see some of my work, you understand the meaning of "hack" in hacksaw!
Any chance we could see the shortened and glued frame bit? Thanks. James
How did you cut the body? Hacksaw? Some sort of machine saw? (... ) If you see some of my work, you understand the meaning of "hack" in hacksaw!
There is absolutely nothing wrong with a hacksaw. I'd rather use a hacksaw than an angle grinder for this job. Better precision for one. Then, aluminium requires special cutting discs - the regular ones gum up instantly in alu.
I'd use a good ol' miterbox, with a stopping block to keep the tube's lenght precise. I'd even splurge up for a blade for aluminium.
Hand tools are great for precise jobs.
Or find a workshop with a lathe, nearby
BTW - James, if your workshop is equiped for woodworking, you are set for working with alu 🙂
    44.7 KB
The rails are are almost completely coverd by epoxy, but you can probably tell what's going on in there.
I used JB Weld, pressed into place and smoothed with damp fingers as it set.
Tube just cut with hacksaw; first careful measuring and marking, then keeping to the marks cutting slowly, fine-tuned with large flat file.
    160.9 KB
    93.8 KB
    108 KB
    145.2 KB
It was awhile ago, but I think the way I got the parts to align properly was to screw the shortened tube and bottom threaded ring lightly into place just before the epoxy set completely.
The rails are are almost completely coverd by epoxy, ....... Tube just cut with hacksaw; first careful measuring and marking, then keeping to the marks cutting slowly, fine-tuned with large flat file.
Fabulous and Funky. Thanks for the inside view that tells the story well. I might have filed and sanded the remaining bits of frame and tried to solder and flood it with my favorite CA (Cyanoacrylate Adhesive) Super Glue, although I am not sure that would work as well. Your way is simpler and obviously viable. Nicely done old man. James
CA wouldn't work so well in this case. Epoxy is better, more apropriate technically and allowing for more flexibility while assembling.
CA is great on smooth, closely mated surfaces. It's an anaerobic glue. It hardens in the absence of air or in the presence of a catalyst. Outside the joint it gives no structural strenght. You cannot flood nor fill the gaps. This is where epoxy shines. Here, @k brown created a kind of "sheath" around stubs. This "sheath" has structural strenght. CA would just dry out and flake off.
In this case the stubs miss each other to an extend (frame is tapered! Ca. 5 mm difference between top and bottom). This leaves really small contact area. To attempt to use CA with some success you'd have to shave the rails off the top plate, cut frame to lenght, smooth the stubs' ends as much as possible, make sure those ends are cut in one plane, parallel to the top plate and glue them to the said plate. Not stub to stub. This creates requirement for perfect positioning.
Use epoxy ... 😁
Use epoxy ... 😁
OK, you win.
And yet . . . Um . . . er . . . in my defense, I only said I MIGHT use CA glue . . . :) :)
Seriously, you make several good points in favor of epoxy. My only objection to epoxy is having to mix and mess with it. (I can overlook the increased cost - it is hard to find at the dollar store.) I have tried both the dual-tube syringe style dispensers, and the mix-in-a-dish variety which leaves globs in the dish afterward, so I prefer a single dose, premixed glue whenever possible. In any case, you present a good case against CA glue for this application! Thanks for the helpful info. James
Yup. Epoxy is messy. I use nitrile gloves (it allways(!) gets on my fingers somehow) and mix it on a throw-away piece of paper or cardboard.
Due to very tight space (afterwards) I'm thinking: long screws or threaded rods, thin tube spacers - screw it all together. Easy to service, not messy. Lack of lateral stiffness helps with selfcentering of top and bottom discs. Would add cut outs in the bottom disc to facilitate access to screws holding the headbasket.
But first I need to make suitable PCB....
YES. Good idea to . . . screw it up. :)
Seriously, I like that idea, even if it entails greater effort. Instead of threaded rods or long screws, you might consider brass or similar metal internally threaded/tapped standoffs with greater diameter that have direct standard threading and provide more substantial bracing. You would simply drill holes for the threaded bits, and screw directly into the spacer/standoffs - It think these would look better and provide more substantial connection from top to bottom inside the body. (See photos)
Good luck with the PC board. James
I hope I won't 😉
These I plan to use for the PCB.
Long screws/rods will provide necessary taper. Standoffs, not so much. They'd go straight through the board, instead of edges only. This may complicate things a bit.
Thanks for advice though 👍
Thanks, I will need that 😉
