This is great for cutting traces, very sharp.....Japan Quality ;D
http://www.conrad.fr/ce/fr/product/529613/Cutter-spcial
Kingston said:The bottom of those silentarts boards is very clearly laid out. It's easy to cut traces even if the board is populated already. I do this just by twisting a sharp knife tip at the trace. Dremel is a too powerful tool most of the time.
please continue the work that you have begun! I want a Fairchild compressor that actually does what a Fairchild does and is functional. Unfortunately the drip 670 is too expensive when you total the cost of everything. I actually found some great info on a guy who has actually started a company who remakes Fairchild 670's. He handmakes two different models mk1 and mk2. He has found a cool way to recreate the Fairchild sound without all the expensive parts. I'll upload the links and info he has on his units. He sales them for 4990£ and the are as I stAted hand made totally from knobs to the case to transformers. The only prob is that he is stationed in Europe and there is a wait time for construction and shippingKingston said:alexc said:So - while I have no doubt that these things can improve performance on it's predecessor, it remains very close to it!
Along with the new features and the simplification of the psu design and build, it could well represent a real step forward in buildability and stability. And an incremental improvement in performance, tube and other matching issues allowing.
I would surely see it as a MkII version of the mighty and controversial PM660 (actual might may vary)
Fine, I'll keep this new proto to myself then, since it will always be just "MKII". A variable load DOA sidechain with threshold, which further simplifies the PSU and improves performance and safety, needs one less transformer, has an easy to use tube matching rig incorporated to it. But like you said "remains very close to the original". Since apparently all this design is as simple as "adding a cap" looks the folks here can take over. As a bonus I no longer have to shift through datasheets, calculate bias points and loads or measure a thing.
If only somebody had told me earlier it was this easy!
toolboxmuziq said:I want a Fairchild compressor that actually does what a Fairchild does and is functional.
toolboxmuziq said:Unfortunately the drip 670 is too expensive when you total the cost of everything.
emrr said:Once you count hours as dollars
MicDaddy said:With regards to your schematic, you have a dual pot(?) showing 25k on the secondary of T3 whereas the original had dual stepped attenuators at 15k. What is the reasoning for 25k? Are there any adverse effects when using 15k stepped attenuators with your redraw? (I already have Elmas built to 15k via log taper).
MicDaddy said:Also, I cannot find the post of ChuckD's relay power scheme, if you have a link or any insight into how this is implemented I'd like to take a look. I believe what happens is that when/if the heaters go down, the relays disengage, and B+ isn't allowed to reach the plates... am I on the right path?
Kingston said:MicDaddy said:With regards to your schematic, you have a dual pot(?) showing 25k on the secondary of T3 whereas the original had dual stepped attenuators at 15k. What is the reasoning for 25k? Are there any adverse effects when using 15k stepped attenuators with your redraw? (I already have Elmas built to 15k via log taper).
Doesn't make a difference whether it's a total of 20-100k in this attenuator. Just needs to be "reasonably high impedance" and you interpret that as you please. Simply use the dual log pot that is most available to you. 15k doesn't exist. Rotary switches are pointless here. You'll never be able to match the gain reduction of two channels perfectly enough to get any use of even 5% tolerance pots.
I don't know about anything ChuckD has done but I've certainly implemented B+/heater fault protection in several projects. I've since found out heater faults don't exist. Don't bother with this. The way it works is that if heater 6.3VDC or 12.6VDC somehow dies (note, it never does), it also turns off a 5V or 12V relay that normally lets in all the B+ VAC voltage. Position is before the B+ rectifier etc PSU parts.
Feedforward option might be an acquired taste.
geoff004 said:Kingston - thank you for your time and effort in to this project.
I built a PM670 for a friend 4 years ago or so. It never really worked well. Balancing left and right wouldn't work with the attenuators I built and linked the 2 channels didn't really work together.
But the inherent sound of the unit was (is) great.
After some frustration with it (and some fried components) I picked it up from him the morning that this tread was started.
Anyhow, I kept the original power supply and added or removed things on the audio side according to the schematic posted on the first page. I added 2 small boards built on cheap radio shack PC board. One board has the 100R resistors and the 10uf caps. On the other board I put all the components between transformers 2 and 3. It's also got relays to handle the switching.
Besides that I cut a bunch of traces on the PCBs and stuffed things where I could. A couple things fit on the underside of the boards. I did not change Q1.
The end result is really great. Not much else to say.
I'll add that the stereo link works great and the meters track nicely too.
duantro said:Hey Geoff004,
Did you also keep the same voltages as the pm670?
