The proof is right there in the photo: the AKG CK6 contains a CK2 omni capsule and a CK1 cardiod capsule. The switch selects either capsule, or the two mixed out of phase.I'm not sure that's right. An omni and bidirectional can give you cardioid, depending upon how the signals are mixed. An omni and a cardioid should just give you omni, sub-cardioid, cardioid depending upon how the signals are mixed. You can get bidirectional from two cardioids back-to-back.
I'm not sure either, but considering Card= 1/2(Omni+Fig8), one could writeI'm not sure that's right.
Yep - my tests with a pair of Behringer B-5s show this to be true; deepest 90 degree null is with card up 6dB.I'm not sure either, but considering Card= 1/2(Omni+Fig8), one could write
2Card-Omni=Fig8
Processing is not only reversing polarity, it should also apply gain of 2 on the cardioid.
Mixing a coincident cardioid mic and an omni results in a fig8 polar pattern. Mix the omni out of polarity with equal sensitivity. A "downside" is anomalies at shorter wavelengths compared to the space between two small diaphragm condensers (SDC), beginning above 9kHz for 19mm (3/4in) center to center (An LDC mic breaks down on its own above 9kHz). Mixing coincident mics equally reduces noise, as the correlated signal gain is 6dB while the uncorrelated noise gains 3dB, for an improved SNR of 3dB.
The math (ideal) is (Acr + Bcr*cosC) - Aom + B*cosC) where the coefficients (A, B) are each mic's (pressure, velocity) and C is the source angle off axis. The coefficient-only shorthand for a cardioid (cr) minus an omni (om) is (1, 1) - (1, 0) = (0, 1), which is a fig8. Note that native fig8 mics are single diaphragms having, if SDC e.g. a Schoeps MK8 or CCM8, fewer HF anomalies, but not the improvement in SNR.
[corrected]Any two coincident microphones with different polar patterns can be mixed to algebraically add to any other pattern. The math can be fun making a cardioid from a fig8 and an omni, a fig8 from two cardioids, or a hypercardioid from a fig8 and an omni. Here’s how using SDC mics…
The polar pattern for a "1st order cosine" microphone output level is L = A + BcosѲ where A is the non-directional (pressure) coefficient, B is the directional (velocity) coefficient, A+B adding to 1.0, and Ѳ is the incident angle (in 3D). So a cardioid, expressed as L = 0.5 + 0.5cosѲ, can be made by mixing a coincident -6dB attenuated fig8 (A=0, B=0.5) and an equally attenuated omni (A=0.5, B=0). On axis, an ideal cardioid's output (rotated about its axis in 3D) is 1.0; at 90deg off axis it is 0.5 (-6dB); in back it is 0.0 (-∞dB).
In this way, you can make a fig8 using two cardioids aimed opposite as L1-L2 = 0.5 + 0.5cosѲ -0.5 + 0.5cosѲ, where the opposite mic's cos coefficient is minus a minus, or a plus, adding to 0.0 + 1.0cosѲ, the expression for a fig8. (A popular application is M-S using three cardioids, the S mixed from two cardioids aimed left & right mixed equally out of phase for a fig8.) Or make a variable hypercardioid (A=0.25 to 0.33, B=0.75 to 0.67) by mixing e.g. about -3dB a fig8 (A=0, B=0.71) and a -9dB attenuated omni (A=0.29, B=0).
Other combinations prorate A & B to arrive at the coefficients of any desired pattern: a wide cardioid (A=0.75 to 0.67, B=0.25 to 0.33) can be approximated by mixing a -9dB attenuated fig8 (A=0, B=0.29) and a -3dB attenuated omni (A=0.71, B=0). Understanding this reveals some "audio malpractice:" A typical host-guest interview with two cardioids close together is the same as a single omni. And many recordists do not envision when aiming a directional mic or combination above that its polar pattern is actually 3D, spun about its axis.
Mixing a coincident cardioid mic and an omni results in a fig8 polar pattern. Mix the omni out of polarity at cardioid gain of 6dB, after matching on-axis sensitivities. A possible "downside" is anomalies at shorter wavelengths from the spacing between two small diaphragm condensers (SDC), beginning above 9kHz for 19mm (3/4in) units. LDC mic pairs break down above 4kHz.As was done with the AKG CK6, combining an omni and a cardioid out of phase, one gets a figure-8 pattern.
Anyone ever DIY'd sich a thing?
Curious if it has sonic advantages over the back-to-back cardioids approach.
I tested with two Behringer B-5 bound together; 90 degree null wasn't perfect at highest frequencies, but about the same as I've heard on Sony's top-line MS mics. Dropping the hi EQ on the card mic at the mixer improves the null considerably.Simplest thing that comes to mind is to test the concept using two end adress mics bound together. I would go for two that have identical frequency response, i don't think you would get desired effect if responses are different.
[corrected]I'm not sure either, but considering Card= 1/2(Omni+Fig8), one could write
2Card-Omni=Fig8
I deleted it myself because I felt it was peevish and unnecessary.Somehow this notification 7/6/24 from the OP k brown has disappeared…
OP - “Not sure what the point of all this 'mathing around' is. A cardiod mic coincident with an omni, then mixed with the omni down 6dB, and you get figure 8. All I asked is if anyone has built a DIY mic using this idea. Further, if such a mic had sep outputs for the two capsules, they could be combined in phase or out of phase to achieve every possible polar pattern, but with the advantages of an SDC. Though I realize this is a pretty LDC oriented place .”
RCAguy - Sorry if the OP isn’t interested mathematical modeling - I posted it hoping some in this conversation would, as it leads to knowledge of what's possible, and saves a lot of trial & error.
To his specific question, I’ve used extensively - after understanding the math - every combination of two or more mics from a cardioid-omni pair to M-S to dual M-S surround to OCT surround to discrete Ambisonics. Cardioid minus omni works IF, after compensation to match on-axis sensitivities, you sum and select polarity using a mixer with neither nominally at +6dB - it works. Compared to SDCs, HF anomalies using LDCs begin above 4kHz, so are troublesome.
Ah, I suspected a computer glitch. I’ve deleted quips myself, and I’ll take down the quote. But I’ll leave my point that even relatively simple math modeling can open up possibilities and save trial & error. My difficulty is explaining it clearly.I deleted it myself because I felt it was peevish and unnecessary.
Besides any difference in capsule diameters (affecting HF >4kHz for an LDC), there's the matter of proximity. For many proximity-compensated cardioids, bass will roll off while the omni remains flat. The fix is to compensate the compensation before summing. It's a bigger deal with an omni and a fig8, e.g. a Schoeps MK8 or cCM8 is compensated flat at 12in (30cm), but rolls off below 200Hz at greater distance.DIY-wise, I'm imagining something like the Josephsn C700A, but with an SDC cardioid in place of the LDC capsule.
The C700A has a five pin XLR, and comes with a breakout y-cable for processing the two outputs individually.
I really should have titled the thread "Omni plus cardioid for any polar pattern.", because if built with separate outs, like the Josephson, it can do any polar pattern; it's just much easier and cheaper to build with cardioid and omni SDC capsules, than with an omni SD and a figure-8 LDC.
With the two outputs mixed in phase it can go card > subcard > open card > omni.
With them out of phase, card > supercard > hypercard > figure-8.
Theoretically, the advantage I see over back-to-back cardioids is that the spacing between the two cards introduces anomalies that vertically-aligned, front-facing capsules wouldn't have. Also much easier to build than something like the Neumann KM 86, with that diffuser disc between the spaced capsules.
Agree, "HF anomalies >9kHz for SDC mics" are inaudible, but >4kHz can be audible using LDC mics that paired have greater center-on-center distances.The HF anomolies are of little practical concern, as the vast popularity of Mid Side mic'ing shows.
