beatnik said:
what are the cons of having a single in transformer for both line and mic sources?
Few if any. With the current design, the mic preamp has gains of 40,37,34,31,28,25.22,19,16,13,10 and 7dB. At the line input you have a 33dB attenuator at the front followed the 20dB gain from the input transformer so the level at the preamp input is at -13dBu for a 0dBu line input. So for a nominal line input, the mic pre is only asked for 13dB of gain. From this point, the gain can be reduced by 6dB to cater for hotter inputs and increased in 3dB steps to cater for lower level inputs like -10dBu consumer sources. The normal compromise with this method is in noise performance because, as a rule, all attenuators worsen noise. However, in this case, the limiting noise source is the output noise of the mic preamp which, as I said earlier, is around -80dBu until the preamp gain reaches about 20dB when the input noise begins to dominate. So, bottom line, noise performance is not affected.
The 33dB attenuator is designed to look like a 150 ohm source to the microphone transformer. To do this, the attenuator consists of two 3.3K resistors and one 150ohm resistor. This means the input impedance of the line input is about 6.7K which is a bit less than the standard 10K bridging impedance but is fine for the vast majority of sources. If you were really concerned about that you could use two 4.3K resistors and a 200 ohm resistor which gives 32.8dB attenuation and raises the input impedance to about 8.8K.
The level reaching the mic transformer is around -30dBu which is well within its capabilities so distortion is not going to be an issue. You might think that a 1:1 line input transformer (10K:10K)would have a better frequency response than a 1:10 mic input transformer (150:15K). However, they have very similar secondary impedances, hence similar inductances, hence similar HF and LF losses.
