I have set up a Mark directory to contain all the info about the Mark3 as it becomes available, I have set up three, hopefully self explanatory, sub-directories called modules, 8tracker and monster (for the one metre monster). The prototype 6U PCB layout is in the modules section:
One the left youcan see it is very much like the currebt EZTube Mixer mic pre. It has had some of the tweaks now built into the V2 TLA i.e. internall connections on Molex KK connectors, preset gain pot for gain make up stage moved to near the front panel, tubes moved out of the way of the module case and the 1N4007 series HT diode to prevent accidental incorrect connection of the HT supply.
At the bottom right you can se the three places for Grayhill EQ switches assumed to be common to all EQ types. The actual EQ and its specific controls will be on a daughterboard above these switches. It will be mounted on pillars fitted to the holes labelled P1 thru' P4.
Above the switches you can see the space for the new PCB mounting Carnhill output transformer. This is electrically identical to the VTB 2291 and has its own number which is VTB2473. To the right of the output transformer I have left room for an additional unassigned input transformer.
Above the transformer is the second 32 way connector. Pins have not yet been finally decided but at present there is provision for two outputs (connected to the mic and line in positions of the original 32 way connector), four AUX buses (where the buses are on the original connector) and four pins for AUX power (where the HT and heaters are on the original connector). The reason for this initial assignment is simply to allow the existing mother board to be used for the second connector.
There is also a picture showing how the PCB slides into the Fischer 6U cassette:
ian
![6UprotoPCB.jpg](https://proxy.imagearchive.com/3f3/3f3447907d19d850b759da352ff6c2f8.jpg)
![6uModuleplusPCBupscaled.jpg](https://proxy.imagearchive.com/6e3/6e33edce09d0c9f8926a30f6de1f0ac6.jpg)
ian
