I think tube amps over the years have had all the guts taken out of them ,once upon a time you had your bassman or bluesbreaker ,gutsy lowdown grunt ,not shrill or screachy like the modern boxes ,nipping out the odd vol bypass cap helps a bit,fx loops with sillicon chips ,gone.
you gotta be carefull not to encroach on your bass players frequencies with such old style amps though ,100w marshall 4x12 ,fat channel with neck pickup ,way way to much mud even on a strat,les paul and your getting down in siesmic low end ,something I always liked about the Orange amps ,FAC (frequency attenuation capacitors) ,you can pull out the wallowy low end nicely before the output stage .Savage treble boost just aint the same as bass cut though
Say Im eq'ing a 58 on vox ,first job cut the bass ,99% of the time you get the bass weight right ,theres very little else needs anything doing ,start from the treble end ,you just end up making a mess .
I once had a home brew 4xel84 style ac 30 dropped into me ,anything above nominal volume and the thing howled with feedback ,like a cat being strangled down a back alley . I set it right so it didnt osscillate,,never had a chance to get the owners opinion on it though ,its just so hard to know how a customer will take a mod ,my guess he was out of sorts till he found his levels again . Took some cobwebs out of a farily well known players amp one time ,the security heavies eventually payed up the hard cash ,after trying to corner me in the back of the venue for their inepptitude and not having a can of iso spray handy .Jmp's have just about the right balance for me ,ones without the master volume always took effects pedals better too .
anyway Cheers Cj ,always an inspiration and an education .
