Normally a reliable enough unit these from my experience,
Customer complains of loud noise at switch on ,
First few times I powered it up no problem apart from a noisy fan bearing which Ive seen a lot on that series of amps , it rattles a bit for a while then the noise goes away , a small drop of light machine oil on the fan bearing sorted that out .
Anyway I pull the PCB , everything everything seems good , I tidy up some of the wiring with a few extra cable ties mainly just to stop various wires crossing over each other in close proximity. I re-assemble ,switch on and the all merciful crunch crackle bang reveals itself . I dismantle the output chip/fan assembly to find some of the heat sink compound across the legs of the TDA 7293 output ic , I clean, re-assemble , seems to be working faultlessly now again.
This amp may not have been getting much use , it could be an issue with the filter caps charging or needing to reform . Ill leave it on for an extended period and see how we go . Any ideas or suggestions welcome.
